Need help nodding my mouse
Solved by W-L,
11 minutes ago, Kavaton said:Hey guys I need help, I'm planning on painting my Logitech g502 Proteus Spectrum mouse white, however I do not know how to take it apart or what paint/sealer to use. Please help!
This guide here shows it being torn down quite well as for painting the unit you will need to sand/prep the surface for primer and paint, and ideally a clear coat to give it some extra wear resistance and protection. Another option would be to vinyl wrap it which wouldn't see problems with wear.
http://blog.siddv.net/2014/09/logitech-g502-proteus-core-teardown.html
