So, I need a new computer for casual gaming and some multumedia stuff. I'm not planning on playing all the new games and expecially not on ultra or even high. Anyway here is what I was able to come up with so far:
Cpu: amd fx-8350 or intel i5-6400
Gpu: gtx 750-ti
RAM: 8 or 16 gb ddr3
I don't care much about the case and motherboard as long as they are compatile with the rest of the stuff. As for the power supply and cooling I have no idea :D
My budget is around 600-650 eur (660-720usd) but all the stuff  costs like 20% more where I live than in the us.
All suggestions are welcome :D thanks
https://linustechtips.com/topic/640558-need-help-for-a-new-build/
which part of europe do you live in?
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  (€204.49 @ Mindfactory)
Motherboard: Asus H110M-K Micro ATX LGA1151 Motherboard  (€58.68 @ Amazon Deutschland)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  (€45.89 @ Amazon Deutschland)
Storage: OCZ Vector Series 128GB 2.5" Solid State Drive  (€59.90 @ Amazon Deutschland)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€49.99 @ Amazon Deutschland)
Video Card: EVGA GeForce GTX 750 Ti 2GB Superclocked Video Card  (€129.31 @ Mindfactory)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  (€56.22 @ Mindfactory)
Total: €604.48
Generated by PCPartPicker 2016-08-09 15:39 CEST+0200
And then you can select a case.
CPU: i7 4770K  |  Corsair H80i  |  ASUS Z87-Pro  |  8GB Corsair 1866Mhz  |  GPU: MSI Gaming X RX 480 8GB  |  Corsair HX  750
PCPartPicker part list: http://de.pcpartpicker.com/list/8gTHzM
Price breakdown by merchant: http://de.pcpartpicker.com/list/8gTHzM/by_merchant/
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  (€67.99 @ Amazon Deutschland)
Storage: A-Data Premier SP550 120GB 2.5" Solid State Drive  (€41.38 @ Amazon Deutschland)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€53.90 @ Amazon Deutschland)
Other: RX 460 (€110.00)
Total: €592.66
Generated by PCPartPicker 2016-08-09 15:47 CEST+0200
same list as funtron, just better value for money. 16 gb of ddr4 is worth less per gb than 8gb. around $15 more expensive for double the capacity
Total: €592.66
Thank you I will take a look at it. As for the RAM, I will most likely take the 16gb but I just wasn't sure what the price of the rest od the components would be.
Total: €604.48
Thank you.
