So guys, this are the available parts in my country. Is this build good?
CPU: Intel Core I5-6400
Motherboard: (EMAXX EMX-IH11 TX -GAMING) or (Gigabyte H110)
Memory: Kingston Hyper X Fury 4gb DDR4 (2x) = 8gb
Video Card: Palit GTX 750
Power Supply: Thermal take Smart SE 739W (SPS-730m)
Case: Thermal Take Versa H21
https://linustechtips.com/topic/640475-pc-build-help/
Not that PSU please. Anything from Seasonic, Super Flower, XFX (except the XT line), Antec's HCG and HCP lines and EVGA's B2/BQ/G2/GS/GQ lines. Also, wait for the RX 460 as it'll get you 950 performance for 750Ti prices.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/640475-pc-build-help/#findComment-8257191
Alright i'll look for those items.
https://linustechtips.com/topic/640475-pc-build-help/#findComment-8257201
4 minutes ago, TheRandomness said:
Just saying, 450W would be fine for your PC but 550W would be nice for future expansion.
Okay, So the only thing I can change for now is the psu to be able for future expansion, is there anything else I must change so that it can be upgradable,?
https://linustechtips.com/topic/640475-pc-build-help/#findComment-8257240
Are you anywhere near metro manila? Can you order from stores like PCHub, Dynaquest, etc or are you gonna be picking up parts from any other store?
Magkano budget mo in Php?
  • Quote people's post else they won't know you replied.
Crapware | 4670k | Hyper212X | GSkill RipjawsX 16GB | Sapphire R9 280x VaporX | 840EVO 120GB | 1TB BLACK + BLUE
Logitech G102 | Corsair K70 MX Brown | HyperX Cloud
https://linustechtips.com/topic/640475-pc-build-help/#findComment-8257283
50 minutes ago, HeyHey said:
~snip~
Hi there :)
What's the purpose of the build? What applications or games and settings are you after? Any budget and country?
The parts that you have listed should work fine together but there are a few things that I could point out:
- you could go with a single 8GB memory stick instead of 2x4GB for budget and future upgrade-ability purposes. You shouldn't really notice the performance difference if you are gaming on this build.
- you haven't listed any storage device. Are you reusing old drives? If yes I would strongly recommend testing their health to make sure they are still healthy to hold the data of your new build.
- depending on your purposes and budget you may need to go for a newer or better performing GPU.
Post back with some more info!
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/640475-pc-build-help/#findComment-8257326
If this is intended for gaming then get an i3 and a more powerful gpu.
PCPartPicker part list
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  - 5.7k
Motherboard: Gigabyte GA-H110M-H Micro ATX LGA1151 Motherboard - 2.8k (this or the GA-H110M-DS2 DDR4)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory  - 1.9k (any single stick 8gb ddr4 <2k)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  - 2.4k
Video Card: AMD RX 470 - 12k (give or take, no prices announced yet)
Case: Thermaltake Versa H21 ATX Mid Tower Case - 2.2k (any case 2k and under with usb3.0 hub at the front, try looking for tecware cases in that price range)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply - 2.6k (best psu you can get under 3k)
https://linustechtips.com/topic/640475-pc-build-help/#findComment-8257643
Yes I can order from that stores and my budget is Php 20k
3 hours ago, Captain_WD said:
Hi there :)
Captain_WD.
I am trying to build a simple gaming pc for a budget of $500 and I am from Philippines. I almost forgot about the storage device! thank you for mentioning it xD
Alright thank you, i'll look for this parts if it;s available
https://linustechtips.com/topic/640475-pc-build-help/#findComment-8257917
23 hours ago, HeyHey said:
~snip~
Let me know if you need any help with the storage devices. For such a budget build a simple WD Blue would be a great solution.
Captain_WD.
https://linustechtips.com/topic/640475-pc-build-help/#findComment-8263270
