Power Supply question
Go to solution Solved by Cyndre,
You're welcome.
1 minute ago, Cyndre said:
Well, i guess you can figure that out when you decide to purchase the PC. (if you have the Amazon Prime or Premium Newegg)
I left some headroom on your ram in case you want to get another kit.(be sure to get the exact model i provided with the one provided)
As with the SLI setup. I hope you know that SLI does not increase the performance as you may think. Look at the video that Linus did on SLI, and you will see its not always worth it and can sometimes reduce performance instead.
isnt it a phys-x card that doesn't effect it though?
Red Panda has been updated with the H440 Case, and x2  Asus 1070's.
You can decide on which vendor to get the parts from, but keep in mind prices of each one is different.
Desktop:
Intel Core i7-6700K 4.5GHz Corsair H100i v2 | Asus Z170-A | Corsair Vengeance LPX 16GB 2x8 3200Mhz | Samsung 960 EVO 1TB + 850 EVO 250GB + Seagate 1TB | GIGABYTE GeForce GTX 1070 G1 Gaming Cooler Master MasterCase Pro 5 | EVGA SuperNOVA G2 650W 80+G | Microsoft Windows 10 Home 64-bit (PcPartPicker)
Yes, most factors will affect the SLI's performance gain. Some applications handle SLI very well.
Desktop:
You're welcome.
Desktop:
