Recently my router has died (currently using ASUS RTN66U) and I need to buy a new one, I have 5 devices wired in with about 25 wireless devices connected at any one time with a external hard drive connected for remote access to files through the router.  Routers use is mostly for gaming, video streaming and a file server that is mostly used for backing up data.  My question is what are some good router options in the sub-$150 price range and that I don't need to load third party software on to get good use out of.
Thanks
https://linustechtips.com/topic/640276-router-replacement-current-rtn66u/
Thanks
I recently purchased the TP-Link Archer C7 router for my fiancee's family. It's a great router and a great value - you can often find it for around $100.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
Thanks
wireless ac with 5 ghz to separate from more common frequencies has served me so well i have looked no further any reason to improve my wireless home network. mine is a netgear nighthawk. you should be able to get one within your price point. just focus on 2 things dual band and wireless ac standard and you should be fine. mind you i stream a locally operated plex server as well as remote ones in addition to competitive gaming without a hiccup.
