problem
Go to solution Solved by DrMacintosh,
4 minutes ago, ZaTrox said:
well i got a pc from my friend and i can't turn it on, i mean it turns on but after like 5 sec it shuts down
as for the specifications, i simply don't know, its 3years old pc and its made by zoostorm, and model number is 7010-0276
to me it sounds like problem with psu but i don't really know much about pcs
Open it up and disconnect/reseat (pull it out and put it back) everything, after that clean out the PC case and the board with a microfiber cloth/compressed air and plug everything back together again. If you get confused on the specifics sending pics of your progress would allow us here on the forum to guide you through it.
https://linustechtips.com/topic/640213-problem/
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/640213-problem/#findComment-8254745
ok, funny thing is that right now i tried to turn it on again and it worked xD, however i will still clean it
https://linustechtips.com/topic/640213-problem/#findComment-8254761
lmao
https://linustechtips.com/topic/640213-problem/#findComment-8254764
