I looked in the Taskmanager and it said that my processor is running for 12 Days now. Wtf?
My Build:
I7 4770k(3.7Ghz)(Watercooled, Astek 510LC)/Asus GTX 1070Ti Strix Advanced/1600 MHz DDR3 12GB/ASUS Z87-M G30AB/Kingston RBU-SC400S37128G 128GB SDD/Toshiba DT01ACA100 1000GB HDD/Acbel R88 ATX12V 700W /Windows 8.1 64 Bit
https://linustechtips.com/topic/640195-cpu-running-for-12-days/
3 minutes ago, Kadleli said:
I looked in the Taskmanager and it said that my is running for 12 Days now. Wtf?
are you on Windows 10?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/640195-cpu-running-for-12-days/#findComment-8254578
uptime only resets when you shutdown or restart your computer, I dont sleep and hibernate counts.
https://linustechtips.com/topic/640195-cpu-running-for-12-days/#findComment-8254580
no, 8.1
My Build:
https://linustechtips.com/topic/640195-cpu-running-for-12-days/#findComment-8254582
my computer was off 6 hours ago
My Build:
https://linustechtips.com/topic/640195-cpu-running-for-12-days/#findComment-8254587
Just now, Kadleli said:
my computer was of 6 hours ago
can you post a screenshot of it?
https://linustechtips.com/topic/640195-cpu-running-for-12-days/#findComment-8254591
i shutdown my computer everytime and it shows 1 day usage :P
no, 8.1
oh right, i think its something to do with some Windows settings. Mine says 1 day and 9 hours of usage lol :P
Old Rig
https://linustechtips.com/topic/640195-cpu-running-for-12-days/#findComment-8254592
how do i do one?
My Build:
https://linustechtips.com/topic/640195-cpu-running-for-12-days/#findComment-8254594
Wah-!? You mean you DON'T let your computer on 24/7? Blasphemy!
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/640195-cpu-running-for-12-days/#findComment-8254628
My Build:
https://linustechtips.com/topic/640195-cpu-running-for-12-days/#findComment-8254638
