build Suggestions for build
Solved by Energycore,
A Hyper 212 EVO is barely enough to cool a stock 5820K, and if you're going to render video, you should take the 5820K anyway.
But do cool it well please. Use something like the GamerStorm Assassin.
CM G650M is fine, but you might be able to find a better model. I can help you if you link me to an online retailer.
http://www.tomshardware.com/reviews/deepcool-gamer-storm-assassin-ii-cpu-cooler,4339.html
