Spec are:
I7 6700k (not overclock yet)
16Gb
EVGA 980Ti
Corsair 100r case (with glass)
Under load my EVGA 980Ti tops at 91c with ambient case temp at 52c. This is with the stock case fan and two cheap fans in the front. I decided to upgrade the fans and move thing around. I remove the HDD cage move storage the a empty 5.25 slot. So nothing is blocking the front fans. I picked up a Corsair AF120 for the rear, two NF-F12 for the front, and used one of the cheap fans at the top. Once everything is back together, temps are still just as high. The front grill of the case is pretty restricted and I don't "feel" much more air flow using the NF then the cheap fans.
My next ideas are to use fans with more CFM in the front and rear or look into watercooling the card (which I kind of don't want).
Any help would be great!
Thanks!
https://linustechtips.com/topic/639565-help-with-high-980ti-temp/
What is your ambient temp? That plays a huge role.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
try replacing the thermal paste on your GPU
Current Setup
CPU: Intel Core I5 6600K with Deepcool frostwin v2.0 twin tower
Motherboard: Gigabyte GA-Z170XP-SLI
Memory/RAM: Avexir Core Series 8GB SDRAM DDR4 2400Mhz 2x4
GPU: Gigabyte GTX 960 Windforce G1 Gaming 2GB VRAM
Case: AZZA CSAZ-207BL ATX Mid Tower
Storage: Seagate Barracuda 1TB 3.5" 7200RPM
PSU: Corsair MX600M
Sound: Razer Adaros
Displays: 23" LG Flatron W2343T and 24" Acer P244W
Keyboard: XTREME Wired Keyboard and Mouse
Operating System:Windows 10
Laptop: MSI GE62 6QD Apache Pro
Intel Core i7-6700HQ
16GB DDR4
GTX 960M
1TB HDD
Windows 10
This has greatly improved temps. Had just enough arctic 5 left over. Getting 76c with 75% fan speed compared to 91c at 100%.
Temps inside the case are a bit hotter at 55c. Any suggestions on fans for this case?
maybe put some fans on the top and put 1 more in the front
make the fans on the back and the top outtakes and for the ones on the front have them intake
Current Setup
PSU: Corsair MX600M
Sound: Razer Adaros
16GB DDR4
GTX 960M
1TB HDD
Windows 10
