Hi all,
So right now i'm on iOS 9.2 and I wanna update to iOS 9.33 but when I want to update in my settings it said update to iOS 9.34 and I don't want that (don't ask me why). Is there a different alternative for the solution? Thanks in advanced!
I'm part of the "Help a noob foundation"
https://linustechtips.com/topic/639519-iphone-help/
I don't know if this still works, but it's worth a try.
Download IOS 9.33 to your computer (don't ask me how and where to download it) → Connect your iPhone to your computer → Open iTunes → Go the phone tab → Click the Update button + Shift.
This should bring up a dialog box that allows you to chose the update file, so just chose the IOS 9.33 file you downloaded earlier.
Your phone should then update to IOS 9.33.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/639519-iphone-help/#findComment-8248120
