Most intel coolers are compatible since the setup hasn't changed any to my knowledge but here's a list of coolers in no particular order, water or air etc but they are all 1155 compatible
https://pcpartpicker.com/products/cpu-cooler/#c=14
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
https://linustechtips.com/topic/639206-cooler-compatibility/#findComment-8244142
Yes, the coolers are compatible but the stock cooler for the i3 isn't as good the one that comes with the i7. Depending on your case ventilation, it may or may not cool well enough.
https://linustechtips.com/topic/639206-cooler-compatibility/#findComment-8245145
