So I just purchased a 802.IIN Wireless USB 2.0 Adapter for my computer and I have a 5Ghz network. But It only picks up the 2.4Ghz one. Did I buy the wrong product (that doesnt support 5Ghz) or does my computer have some issues or something?
Item: https://www.amazon.com/Belinda-150mbps-Wireless-Adapter-Antenna/dp/B00S7PO3L2
https://linustechtips.com/topic/638793-802iin-wireless-adapter/
2 minutes ago, TheProfessionalAmateurs said:
Cheaper wifi adapters cannot work with a 5Ghz network. Even if it takes a few hours to do, I would recommend running an Ethernet cable through the wall, to your desktop, or using a power line adapter.
yeah cant do that I was either lookig for a card or an adapter
https://linustechtips.com/topic/638793-802iin-wireless-adapter/#findComment-8239586
The Cheap wireless N products are 2.4Ghz only. You need to look for devices that are N 750 or above. I would heavily suggest a PCI Express add in card, never had much luck with USB WIFI. If USB is the only thing, try to find something on a USB extension cable, this way you can at least move it around and find the best reception.
https://linustechtips.com/topic/638793-802iin-wireless-adapter/#findComment-8241540
