Internet won't work after swapping graphics card! Please help!
7 minutes ago, jewishdolphins said:it says "the best driver software for your device is already installed. windows has determined the driver software for your device is up to date: intel(R) ethernet connection (2) 1218-V"
and i tried disabling and reenabling and its not working.
Alrighty then.
You can try to uninstall the driver and then see if it allows you to reinstall it. If it does (It should) do that. If this still fails you will need to put the CD in from your mobo and reinstall the driver from scratch.
Anyway I'm going to be off for a while as its getting late where I hail from (Almost 3 in the morning), so unless somebody else answers you might have to give me a while to get back to you.
Anyway to put your mind a bit at ease till next time, you wont need a new $300 mobo if we cant get it going as you can get incredibly cheap things like this to replace the ethernet port on your mobo.
