USB detection problems after resetting cmos?
Go to solution Solved by RangerLunis,
Turns out my keyboard was just broken :I It was gettin up there in age and it's wires extremely frayed and curled and bent.
Here is my build before I run you through my story:
http://pcpartpicker.com/list/ztHmgL
So I was using my computer as normal until I got a warning about my overclocking, it seemed the voltage was too low,
I restarted the computer and a message popped up that my overclocking had failed.
So I decided to just reset the cmos thinking this would clear everything.
Afterwards, the computer would stay on the rog logo but go no further, with me being unable to use the keyboard. I looked over to my build, and saw asus q code "9c".
I looked it up and it said there was a problem with my usb detection. All the usb headers seem to be plugged in, and all usb ports undamaged.
Any help on this please?
https://linustechtips.com/topic/637380-usb-detection-problems-after-resetting-cmos/
