Reasons For Router Randomly Rebooting?
The Knome
Like the title says, at times the ADSL router will randomly reboot.
So far to try and suss the problem I have:
Tested 3 different routers with all doing the same.
Replaced the cable to the modem with a Cat6 shielded.
Replaced the microfilters.
Check the phone wiring my side (within the realms I am legally allowed to do).
Checked and updated the firmware on the router.
Checked and updated the firmware on the PC for the networking adaptor (just in case, being built in).
Checked every other cable I can muster.
Checked the current and voltage on the mains in case is was some kind of surge.
Been on the phone with the ISP who checked their own modem and called it dead, which has been confirmed after all this work (but borrowed and a new router with the exact same symptoms? minus the refusing to connect at all aspect).
At the moment, got an old spare wireless network card in the main desktop to see if it stabilises, but with the randomness its going to be tricky, as some days its been perfect, no drops at all and other times like last night it just rebooted every few minutes.
EDIT, same result regardless of being on wired, or wireless connection.
At a bit of a loss and looking for any other input from the tech community?
Before I go calling in an engineer to check their side of the wiring want to make sure I have crossed off any, and all possibilities on my end.
Its not my fault I am grumpy, you try having a porcelain todger that's always hard!
I had a similar problem one time... in my case I got the ISP to send an engineer as I knew there was no problem my end. It turned out to be the faceplate where the outside line connects, the connections inside had been melted a bit by a power surge when there was a lightning strike nearby that took out some other ISP equipment. I only knew this as the engineer that was sent was the same one that had to deal with the other ISP equipment a few days earlier.
It may not be the case with your problem, but if you've checked everything else reasonably required at your end then I think an engineer visit is the next logical step. Good luck.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
