On 8/1/2016 at 7:47 PM, SuperMonkey507 said:
The 470 should be an equivalent to a 960 4GB and I only give a shit about the 460 and 470 because of cheap HDR support for an HTPC.
No no no no no no, the 470 is a bit short of midway between a 380X and a 390. It will absolutely destroy any 960.
https://linustechtips.com/topic/636573-radeon-rx-470460/#findComment-8221633
yeah, thats hardly going to happen, maybe it will be up to par with 380. No point in over hyping.
''Daddy CumTits 2.0'' (pc):
CPU - Intel i7 8700k
GPU - Asus Strix 1080 8gb
RAM - 2x8gb Corsair Vengance
MOBO - Asus Prime Z370-p
PSU - Corsair RM750x
https://linustechtips.com/topic/636573-radeon-rx-470460/#findComment-8222077
Just now, TrantaLocked said:
Wat? AMD already showed benchmark FPS numbers. It easily beats the 380X in all games tested.
links then please
https://linustechtips.com/topic/636573-radeon-rx-470460/#findComment-8223165
