i am about to buy a gtx 1070 and my pc parts and great, i would like to know if my cpu will bottleneck the card or my other parts creat problems
apu: Amd 6600k + stock cooler
Motherboard: A78M-E45 V2
psu: 500 watt
Ram: 16gb (2x8) ddr3
fans: 1 back, 1 side, 1 front
the gtx 1070 btw is the msi gaiming x
https://linustechtips.com/topic/636402-will-it-work/
psu: 500 watt
HOLY BOTTLENECK BATMAN
M1 MacBook Air 256/8 | iPhone 13 pro
https://linustechtips.com/topic/636402-will-it-work/#findComment-8213253
it so will bottleneck
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/636402-will-it-work/#findComment-8213254
psu: 500 watt
That ain't gonna work at all. That's the largest bottleneck I have ever seen.
Tech enthusiast and CS Student
https://linustechtips.com/topic/636402-will-it-work/#findComment-8213257
As long as your psu is up to that task, you're good to go. Please list the model name--not all 500w's are built the same.
Yes, the cpu will bottleneck the graphics card in most cases.
https://linustechtips.com/topic/636402-will-it-work/#findComment-8213258
That's going to bottleneck the F S*** out of the GPU holy lord  on high xD
CPU: i7 6700k (4.7 GHz) | GPU: EVGA GTX 1070 FTW (OC) | Motherboard: ASUS Sabertooth Z170 S | Cooling: Corsair H110i GTX | Storage: 250GB Samsung 850 EVO M.2 + 1TB WD Black | RAM: 16GB (2x8) Corsair Vengeance LED (White) 3000MHz | Case: Phanteks Enthoo Evolv ATX | PSU: Corsair RM850i | WiFi Card: TPLink Archer T9E | Case Fans: Noctua iPPC-2000 PWM (3x 120mm in), 2x Noctua NF-A14 PWM 140mm (radiator, painted black), Fractal Venturi HP-14 (1x 140mm out)  | OS: Windows 10 Home 64-bit
https://linustechtips.com/topic/636402-will-it-work/#findComment-8213312
psu: 500 watt
I would see about getting a 1060 and a better cpu/motherboard.
http://pcpartpicker.com/list/GCZMwP
http://cpu.userbenchmark.com/Compare/AMD-A8-6600K-APU-vs-Intel-Core-i5-4460/m3344vs2310
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/636402-will-it-work/#findComment-8213470
