Switch Help
Solved by leadeater,
I use a Cisco SG300-10 which has everything you want plus layer 3 features, static routing only though. It is in your price range ish (I think) but the layer 3 features does push the price up.
Something a bit more in-keeping with what you are looking for could be:
