Need Help With New Build List!
Solved by Guest,
2 minutes ago, Meestagibbon said:
Okay, that's my first plan then, but next question, would it be smarter to move to the newest platform, with DDR4 and M.2 and such, or get a 4790k instead? I wont be using m.2 any time soon and I honestly am happy with a Samsung 850 evo at best.
If it was me I would just buy a new graphics card first off (And psu) and see how it performs. Something like a GTX 1060 would be fine for 1080p resolution, or a GTX 1070 if you want to push the boat out. If you are still not happy then you can look at changing the cpu. An i7 6700K isn't a massive upgrade though over the Xeon.
