You need to go into options to unlock it. By default, it is locked.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Only very specific nvidia cards allow for easy control of voltages of anything other than the core itself. Stuff like the lightning editions from msi integrate with msi afterburner to allow for more granular control.
Even if your card has a custom PCB, I doubt there is anything allowing for the change of vram voltages.
This is all assuming you meant to say VRAM, and not VRM...
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
Yes,  I meant memory.
Well. That's a bummer.
Yeah, nvidia has a very apple like stance on the control the user has over the card where they try to lock down everything they can... Quite annoying when you are trying to overclock and are being limited by silly restrictions and unable to tap the full potential of the card.
I knew this but I though it only applies to the GPU core voltage.
