Hi,
today I updated my avira AV and after I updated it.. I did a scan with Hitman Pro 3.7.14
it detected these "suspicious threats"
avipbb.sys
avgntflt.sys
I also reconnised that my PC is booting up slower than usual it has a black screen with a cursor and then after 10 seconds it boots to the log on screen. Should I delete thes? its found in System 32 drivers :/
Thanks so much!
https://linustechtips.com/topic/634961-help-suspicious-treat/
Quick question: What OS are you running? A quick cursory google search for avipbb.sys (which might have been a better starting point) brought me to this, where a user was having issues with Avira running on Windows XP, which may be out of support at this point (don't quote me on this)
CodeMaster (Name Due for Update):
CPU: FX-8320 @ 4.6GHz | Motherboard: ASUS Sabertooth 990FX R2.0 | RAM: 24GBs Crucial DDR3-1600
GPU: Gigabyte GTX 970 Windforce OC | Case: Fractal Design Define S | PSU: Corsair AX860i
https://linustechtips.com/topic/634961-help-suspicious-treat/#findComment-8197958
20 minutes ago, Inuka said:
It's a false positive. You'll always get false positives when one anti-virus scans another. That's why it's generally frowned upon to use more than one at a time, as they will almost always conflict somewhere.
https://linustechtips.com/topic/634961-help-suspicious-treat/#findComment-8198044
