4 way sli issue
Go to solution Solved by Jumper118,
its alive :D was the sli bridge
when i try to enable 4 way sli on my rampage iv formula it only comes up with 3 way sli even though there are 4 cards installed. does anyone know what i can do to fix this?
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/634742-4-way-sli-issue/
@Jumper118
what cpu do you have? maybe your maxing out the lanes on the processor with 3 cards
Tsubasa (The 7680x1440 beast): CPU: Intel i7 8086k | Cooler: Fully Custom Rigid Loop MOBO: Asus Z370-I ITX | GPU: Nvidia Titan Xp Star Wars | RAM: 32Gb 2x16gb Gskill Trident Z RGB | SSD: Samsung 1TB 970 Evo Nvme, 2TB Micron Sata SSD | Case: Fractal Design Nano S | PSU: Corsair SF600 With Full custom cables
https://linustechtips.com/topic/634742-4-way-sli-issue/#findComment-8195683
1 hour ago, Tyleredbowers said:
what cards do you have in sli
gtx 580
1 hour ago, That_Random_Guy said:
@Jumper118
3930k has 4lanes
Rig Specs:
https://linustechtips.com/topic/634742-4-way-sli-issue/#findComment-8196019
Rig Specs:
https://linustechtips.com/topic/634742-4-way-sli-issue/#findComment-8196105
Is there a reason you want to go with that setup?  Seems you could sell the 4 cards and pretty much have all the cash to buy an RX 470 after the 13% for ebay/paypal fees and shipping costs.  Is Fermi still relevant enough and SLI supported enough for the setup to be useful for gaming?
There's something cool here - you just can't see it.
https://linustechtips.com/topic/634742-4-way-sli-issue/#findComment-8196136
i have 5 of them and i ahve loads of other gpu's as well. i only do overclocking and benching :D
Rig Specs:
https://linustechtips.com/topic/634742-4-way-sli-issue/#findComment-8196244
3 minutes ago, Cracklingice said:
Ahh gotcha so basically fun and experimentation.
yes. i love it. its so silly, but atm i'm destroying 970 sli in valley :) pulling over 1300w at the wall
Rig Specs:
https://linustechtips.com/topic/634742-4-way-sli-issue/#findComment-8196300
Thermi ftw
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/634742-4-way-sli-issue/#findComment-8196331
1 minute ago, Cracklingice said:
Your power company loves you.
yes. for f@h mainly. because thats 400w 24/7
Rig Specs:
https://linustechtips.com/topic/634742-4-way-sli-issue/#findComment-8196466
