First boot ever - No monitor connection
Si I figured my mistake, and everything worked out..! I simply forgot to connect the PSU with the 8 pin 12V connector.. I figured the day after, when some more investigation was done (and manuals read )...
So yeah, pretty dumb mistake, glad it all worked out..! Thank you all for the replies and useful tips!
On 29. juli 2016 at 3:23 PM, Flobberknock said:I have seen cheap adapters online that simply connect the pins over and actually make no attempt to convert the signal, therefore not working at all. I believe their business model is 'some people will be too lazy to return it'. Most VGA to HDMI adapters are quite bulky and relatively expensive (I'm talking £20-£30 rather than hundreds) so if you picked one up for like £3 then it's most likely you got one that doesn't actually do anything
Yeah I was worried about this... the adapter i got actually was quite cheap.. (about 7-8 USD) glad it turned out to be working
