So a while back i posted asking for advice on my PC build list, it was fine for the time before the new generation of GPUs but since then i hav e not been able to build it because of other financial problems. so i've held off and edited my build to utilize these new cards and see what i can get.
My goal for this build are:
1080p gaming at max to ultra settings,
Possible twitch streaming.
some light video editing.
Must be able to run a game at the settings mentioned and have a voice chat and a browser running all at the same time.
Here is the build:
PCPartPicker part list: http://ca.pcpartpicker.com/list/nNYQqk
Price breakdown by merchant: http://ca.pcpartpicker.com/list/nNYQqk/by_merchant/
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($434.99 @ Newegg Canada)
CPU Cooler: Corsair H100i v2 70.7 CFM Liquid CPU Cooler  ($124.98 @ NCIX)
Motherboard: MSI Z170A GAMING M5 ATX LGA1151 Motherboard  ($219.99 @ NCIX)
Memory: Kingston FURY 16GB (2 x 8GB) DDR4-2133 Memory  ($80.99 @ NCIX)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($118.25 @ Vuugo)
Storage: Western Digital Blue 1TB 3.5" 5400RPM Internal Hard Drive  ($64.25 @ shopRBC)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($109.00 @ shopRBC)
Total: $1152.45
Generated by PCPartPicker 2016-07-27 16:27 EDT-0400
My limit is $2000CAD, I am in need of the following:
A GPU to meet the requirements above.
A case with room for one optical drive that does not look horrible. i still have a lot of DVDs and CDs that i love.
One optical drive that doubles as a blu-ray reader and writer.
A pair of 21" monitors that have HDMI and displayport.
As always, i am open to suggestions and changes if they don't impact performance but lower cost. I have all other peripherals required so please do not suggest any of those.
https://linustechtips.com/topic/633652-my-first-ish-build/
slap a 1080 on it and put it in some case you like and you should be fine, you can get the monitors for around $100 or so(for just basic monitors) and the case i would say go for an entho pro, im pretty sure that has 2 3.5" bays and i cant help you with the other stuff but if it gets to expensive then go for a 1070 because the 1080 is pretty overkill tbh
Builds:
https://linustechtips.com/topic/633652-my-first-ish-build/#findComment-8182617
Get 1070 (it maxes out all the games 90+ FPS) or wait for 1080ti.  1080 has terrible value.
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
https://linustechtips.com/topic/633652-my-first-ish-build/#findComment-8182671
Hey Kahman, has the supply of GTX1070's stabilised in Canada? If yes, I would pick up a custom rev. of that card from eVGA or GIGABYTE.
Apart from that, for the chassis, if you want something that looks decent and comes with some internal frills, check out the following (no particular order),
  • Cooler Master MasterBox 5
  • NZXT Source 530
  • Corsair Carbide 400C
  • Be Quiet! Silent Base 600
The Phantek's Enthoo line is wonderful but I have never had the pleasure to work with them because they do not have their hardware in my country. =[
For monitors I would suggest any decent model with the thinnest bezel's possible from BenQ or DELL should keep you sorted. LG is also a contender but they are limited to IPS-panel based displays
Hope this comes handy. Cheers!
https://linustechtips.com/topic/633652-my-first-ish-build/#findComment-8182679
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/633652-my-first-ish-build/#findComment-8182681
For 1080p (if you don't plan on upgrading for a while), a single GTX 1060 or RX 480 should suffice. As for a case, I'm a bit of a Fractal Design fan, since their cases are minimalistic and clean.
CPU - Intel i7-4790k | CPU Cooler - Cooler Master Hyper 212 EVO | Motherboard - Gigabyte GA-Z97-HD3 (Rev 2.0) | RAM - G.Skill Ripjaws X 16GB (2x8) DDR3-1866 | Storage - Samsung 850 EVO 500GB SSD | Graphics Card - EVGA GeForce GTX 980ti SC | Case - Fractal Design Define R5 w/Window (Black) | PSU - EVGA 750W B2 | Display - Acer K272HUL | Keyboard - E-Element RGB | Mouse - Logitech g502 | Sound - Klipsch ProMedia 2.1/Fostex TH-x00/Sennheiser HD595
https://linustechtips.com/topic/633652-my-first-ish-build/#findComment-8182694
9 minutes ago, Kahman10 said:
This does not include any monitors or anything other than what i have listed. I don't know if i was not clear that the $2000CAD limit was to include monitors.
http://ca.pcpartpicker.com/list/nN9tpb
Edited: costs 2004
https://linustechtips.com/topic/633652-my-first-ish-build/#findComment-8182744
Just now, ALPHA17 said:
Would not a GTX1070 be a better choice? Or are they still over-priced due to low availability?
Edited: costs 2004
Yes it would be better but to costly... :(
https://linustechtips.com/topic/633652-my-first-ish-build/#findComment-8182787
2 minutes ago, ALPHA17 said:
^ Ah! I thought you guys would have it better there. If the bugger was in my place, he would be paying about ~$1100 just for the GPU.
Hey kahman, if you can throw $4 in the pot, the GTX1070 is a great GPU to have.
That 4$ is fine, does it include 2 monitors?
https://linustechtips.com/topic/633652-my-first-ish-build/#findComment-8182838
The one I made only had 1 monitor... :( Il edit it brb...
https://linustechtips.com/topic/633652-my-first-ish-build/#findComment-8182855
Here is the build:
Total: $1152.45
For that price I would definitely get either a ASrock Extreme Z170 or an ASUS board, MSI has been kinda funky these days...
https://linustechtips.com/topic/633652-my-first-ish-build/#findComment-8182860
https://linustechtips.com/topic/633652-my-first-ish-build/#findComment-8182862
Considering OP is sticking to 1080p-60fps gaming for now, would it be better to scale back on the processor to a Core i5 6600k and keep the rest of the build same.
Or is the quad-core non-hyperthreaded Core i5 simply too anemic for the task at hand?
2 minutes ago, Kahman10 said:
I also like the Phanteks Enthoo case that was suggested earlier, it has everything i need including possible mod support for later on.
The only issue would be your budget.
https://linustechtips.com/topic/633652-my-first-ish-build/#findComment-8182881
http://ca.pcpartpicker.com/list/my9tpb
How is this? :D
https://linustechtips.com/topic/633652-my-first-ish-build/#findComment-8182910
6 minutes ago, Kahman10 said:
I like this one.
Thank you. :$
I think you can take other members opinions in the performance ▲ between a Core i5 6600k or Core i7 6700k and if there is not sufficient difference to justify the latter, you can go for the relatively cheaper Core i5 and stuff in your second monitor.
Hope this helps, Cheerio!
Here is the base benches from Anandtech.
Edited by ALPHA17
Edit instead of multi-post
https://linustechtips.com/topic/633652-my-first-ish-build/#findComment-8182975
