Hello small question
Go to solution Solved by privoid,
Just now, Kudzė said:
Yeah I just installed 64 bits of Windows 10 inside it. And inside website they say this:  When installing total memory of 4GB capacity or more
Right, I've done some googleing and judging by the forums it's max 4GB. Sorry.
Hello so i want to put 8gb of ram in my system (2x4gb) I have this motherboard: ASUS P5KPL-AM.
Under memory in theirs website it says this:
Memory
2 x DIMM, Max. 4 GB, DDR2 1066(O.C.)/800/667 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Overclock speed
**Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
***When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
But I'm not sure they mean 4gb in total or 4gb per stick?
https://linustechtips.com/topic/633076-hello-small-question/
1 minute ago, brodieslee said:
First of all, did you make sure to buy ddr2 instead of ddr3 memory?
Yeah mate. I'm not that dumb.They wouldn't even fit xd.
And I didn't bought them yet but I'm thinkink aboout these:  CORSAIR XMS2 DDR2 4GB 800MHz
https://linustechtips.com/topic/633076-hello-small-question/#findComment-8171563
Memory
*Overclock speed
I'm sure they don't mean 4GB in total because.. why would they? My brother's also still got DDR2 and he's got 6GB of RAM so it should work.. Also: Make sure you've got a 64-bit OS, because 32-bit has a limit of 4GB.
https://linustechtips.com/topic/633076-hello-small-question/#findComment-8171572
Memory
*Overclock speed
I think max 4GB per DIMM, but the amount of memory it says it supports is normally lower than what it actually will run on.
2GB DDR2 sticks are rather pricey though, and rare.
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
https://linustechtips.com/topic/633076-hello-small-question/#findComment-8171579
https://linustechtips.com/topic/633076-hello-small-question/#findComment-8171587
motherboard only supports 4GB of total system memory, FSB limitation or something, not too hot on older hardware even tho i have loads :P anyway you will not be able to have more then 4GB of RAM it seems
Builds:
https://linustechtips.com/topic/633076-hello-small-question/#findComment-8171623
Sorry, I've had memory limitation before getting my new rig in last years october. I was limited to 2GB of DDR2 sh*t :D
Yeah. It sucks. Well So anyways i'll save up more money and buy new cpu/mb/ram kit anyways because its so old xD marking it solved :)
https://linustechtips.com/topic/633076-hello-small-question/#findComment-8171687
