They make noise whenever the platters are spinning, which is basically while being used in any way.
Power saving features can spin down the platters after a prolonged period of being idle, which will cut noise dramatically.
I do not feel obliged to believe that the same God who has endowed us with sense, reason and intellect has intended us to forgo their use, and by some other means to give us knowledge which we can attain by them. - Galileo Galilei
Build Logs: Tophat (in progress), DNAF | Useful Links: How To: Choosing Your Storage Devices and Configuration, Case Study: RAID Tolerance to Failure, Reducing Single Points of Failure in Redundant Storage , Why Choose an SSD?, ZFS From A to Z (Eric1024), Advanced RAID: Survival Rates, Flashing LSI RAID Cards (alpenwasser), SAN and Storage Networking
https://linustechtips.com/topic/63276-mechanical-hdd-noise/#findComment-865066
Do 3.5inch mechanical hdd's only make noise when writing or is it reading too?
Whenever the heads move around a lot, so reading and writing (I'm assuming you're
referring to the clacking noise).
EDIT: Ninja'd. :D
If you're just referring to any noise in general, then ^this.
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
https://linustechtips.com/topic/63276-mechanical-hdd-noise/#findComment-865067
They're not very loud though, unless your HDD is crappy or dying.
I can hear mine over my system but, I've got everything configured for silence.
Yup. I get annoyed rather easily by PC noise, and even I barely register
modern drives. I did once have a 10k SCSI drive which, being a server disk,
was extremely loud, not just when reading/writing, but just in general disk
spinning mode. It was fast though. :D
https://linustechtips.com/topic/63276-mechanical-hdd-noise/#findComment-865081
