Been a laptop gamer for many years but finally decided to do a full setup for when I do get to spend some time at home.  Started this little project back in january and feel I've made some good progress. I still have some plans to come but thought I would share some pictures of it.  I will apologize in advance for the photos as they were all just taken with my phone and not nearly enough were taken along the way.
PC specs
-4790k 4.8@ 1.3v
-H80 AIO (I was originally planning on getting the H100 but was offered the H80 for free because it was missing one fan but was otherwise brand new)
-32GB Crucial Balistix
-MSI Z97S sli krait
-2X crucial MX200 960gb SSDs
-Gigabyte Windforce GTX970 (This was just to tide me over till I could get a 1080FTW that I have pre-ordered and have still yet to receive it)
-4X 120mm Ring Fans
-2X 140mm Riing Fans
-Custom white cables for the GPU and MB that will be installed with the new graphics card when it shows up.
Rest of the Room.
This setup involves a lot of LEDs that I feel work with the desk very nicely(hell they require their own 200W power supply)The LEDs are also being supplied with 14V and mounted to aluminum stock to help dissipate heat from being overdriven.  I also made up a custom harness for the LEDs so there are disconnects between each section of desk and for each monitor. In these pictures not much time was spent on cable management as I was waiting for my 1500W sinewave UPS to show up but I feel it still turned out fairly nice.  trying to go for a simple zombie theme with black and blue w/ green accents  running throughout.  The upper monitors are on full articulating mounts and can be swung down beside but I much prefer it in this setup(except for Flight Simulators) otherwise I'm only ever gaming on the 3440X1440 34" main display.
I would like to hear suggestions on things that could be improved.
I also did just receive these and am wondering If and where I should mount them.  I'm thinking of mounting the two axes between the window and where the machete rack is and the throwing knives in some sort of pattern above the pc tower.  At the same time I kind of like the simplicity of just the machetes and insane lighting.  Also any good zombie theme ultrawide wallpapers anyone could recommend would be much appreciated.  Its surprising how little ultrawide support there is.
https://linustechtips.com/topic/632645-project-z/
OMG! That is sick! Jealous of this set up!
        MY RIG
Intel core i5-6600k | Hyper 212 EVO | Gigabyte Z170-HD3 | G.SKILL Ripjaws V Series 16GB (2X8) | Samsungs 850 EV0 250GB | WD BLUE 1TB | Gigabyte Geforce GTX 1070 G1 | Corsair 200r | EVGA SuperNOVA NEX 750W 80+ Gold
https://linustechtips.com/topic/632645-project-z/#findComment-8166701
  • 2 weeks later...
Nice PC, good to see you have converted to a desktop, you'll enjoy the power more.
For dual monitor or widescreen backgrounds check this out http://www.dualmonitorbackgrounds.com/
Intel i7 4770k @4.5ghz, Asus Maximus VI Formula, Asus Geforce GTX 780, Corsair h100i, Corsair Neutron GTX 240gb, WD Black 1tb, Corsair 750D, Corsair AX860i w/ Sleeved Cables.
I rarely leave the build logs section.
https://linustechtips.com/topic/632645-project-z/#findComment-8235613
@JokerProduction I've been a laptop gamer for the last 4 years and I've recently built my desktop. You'll enjoy it as much as I am now :D
RIGZ
Starlight (Current): AMD Ryzen 9 3900X 12-core CPU | EVGA GeForce RTX 2080 Ti Black Edition | Gigabyte X570 Aorus Ultra | Full Custom Loop | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 1TB + 2TB M.2 NVMe PCIe 4.0 SSDs, 480GB SATA 2.5" SSD, 8TB 7200 RPM NAS HDD | EVGA NU Audio | Corsair 900D | Corsair AX1200i | Corsair ML120 2-pack 5x + ML140 2-pack
The Storm (Retired): Intel Core i7-5930K | Asus ROG STRIX GeForce GTX 1080 Ti | Asus ROG RAMPAGE V EDITION 10 | EKWB EK-KIT P360 with Hardware Labs Black Ice SR2 Multiport 480 | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 480GB SATA 2.5" SSD + 3TB 5400 RPM NAS HDD + 8TB 7200 RPM NAS HDD | Corsair 900D | Corsair AX1200i + Black/Blue CableMod cables | Corsair ML120 2-pack 2x + NB-BlackSilentPro PL-2 x3
STRONK COOLZ 9000
EK-Quantum Momentum X570 Aorus Master monoblock | EK-FC RTX 2080 + Ti Classic RGB Waterblock and Backplate | EK-XRES 140 D5 PWM Pump/Res Combo | 2x Hardware Labs Black Ice SR2 480 MP and 1x SR2 240 MP | 10X Corsair ML120 PWM fans | A mixture of EK-KIT fittings and EK-Torque STC fittings and adapters | Mayhems 10/13mm clear tubing | Mayhems X1 Eco UV Blue coolant | Bitspower G1/4 Temperature Probe Fitting
DESK TOIS
Glorious Modular Mechanical Keyboard | Glorious Model D Featherweight Mouse | 2x BenQ PD3200Q 32" 1440p IPS displays + BenQ BL3200PT 32" 1440p VA display | Mackie ProFX10v3 USB Mixer + Marantz MPM-1000 Mic | Sennheiser HD 598 SE Headphones | 2x ADAM Audio T5V 5" Powered Studio Monitors + ADAM Audio T10S Powered Studio Subwoofer | Logitech G920 Driving Force Steering Wheel and Pedal Kit + Driving Force Shifter | Logitech C922x 720p 60FPS Webcam | Xbox One Wireless Controller
QUOTES
"So because they didn't give you the results you want, they're biased? You realize that makes you biased, right?" - @App4that
"Brand loyalty/fanboyism is stupid." - Unknown person on these forums
"Assuming kills" - @Moondrelor
"That's not to say that Nvidia is always better, or that AMD isn't worth owning. But the fact remains that this forum is AMD biased." - @App4that
"I'd imagine there's exceptions to this trend - but just going on mine and my acquaintances' purchase history, we've found that budget cards often require you to turn off certain features to get slick performance, even though those technologies are previous gen and should be having a negligible impact" - ace42
"2K" is not 2560 x 1440
https://linustechtips.com/topic/632645-project-z/#findComment-8237249
  • 2 weeks later...
Small Update Picked up a PDP afterglow Xbone controller.  I've been meaning to pick up a controller for awhile now to play all the old school emulators and for forza.  I'm really impressed with this thing and would say it actually is a improvement over the authentic Xbone controllers.  It worked right out of the box no driver issues.
https://linustechtips.com/topic/632645-project-z/#findComment-8308156
  • 3 months later...
Hardly any updates but I did spend a few hours today and redid the cable management and relocated a few components.
And I got a new phone and the pictures seem to be a fair bit better than my old S4 so here is a more updated picture (this was before the new cable management).
Considering changing the case out to a corsair 460x or 570x when they finally come available.
https://linustechtips.com/topic/632645-project-z/#findComment-8899910
I would swap out that H80 asap. I had one on my 3770K a couple of years ago, it made more noise than my 212 at the same level of cooling. Maybe with some good static pressure fans it will perform better. It was that cooler that drove me to custom loops
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/632645-project-z/#findComment-8907103
  • 3 months later...
  • 4 weeks later...
New fiscal year means a new update.
Finally got around to doing the case swap.  Was pretty torn choosing between the 460x and the thermaltake view 31, so when in doubt get the most expensive and I ended up with an anaidees crystal AI.  Also purchased a crucial MX300 2tb but haven't installed it because silly me for assuming a 700$ hard drive would come with the sata cable.  Also picked up some sleeved cables.(and yes I noticed after looking at the picture that I messed up the order putting the cables in the combs. Its fixed now)
Everything swapped over and first power on.
Starting to put the glass panels on
SSD sadly looking at his soon to be home.
And Fully Clothed.(forgive the horrible lighting and reflections)
Wasn't expecting the glass to be tinted quite so dark so I may look at adding some LED strips.
https://linustechtips.com/topic/632645-project-z/#findComment-9623760
Well that didn't last long.  Tint was to dark for my liking so I ended up adding a single strip of RGB leds that I just jumpered to make white and wired that into one the many unused molex connectors I had laying around from my fans.
At this time its just a strip of 18 5050 Leds along the top I *may* add another down the bottom.
Still waiting on the sata cable to add the new HD and another fan for the pull on the radiator.
https://linustechtips.com/topic/632645-project-z/#findComment-9629738
  • 2 weeks later...
