In Chrome I'm getting an issue where I'm not hearing the new post notification sound until I switch to the tab that has the thread on it. I still get the chrome popup notifications. Now the main problem is that for each notification sound that should have played, the sound is that many times louder than it should be: as if all the notification sounds have been building up to all play at once. For threads with 2 new posts this is pretty bad, but when you get 10+ posts this gets deafening.
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
https://linustechtips.com/topic/632141-notification-sound-bug/
On 25/07/2016 at 4:14 PM, colonel_mortis said:
Can you open the dev tools to the console tab, and just leave it open. When you experience one of these, can you then screenshot the console and post it here?
Sure. Nothing out of the ordinary showed up. I see those syntax errors on pretty much every page.
https://linustechtips.com/topic/632141-notification-sound-bug/#findComment-8178123
