Everything seems fine from that.
As long as it's under 80°C, both CPU and GPU, there is nothing to worry about.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/632101-temps/#findComment-8161219
Just now, Will Or occ said:
thats fine right ?
Yes.
https://linustechtips.com/topic/632101-temps/#findComment-8161242
3 minutes ago, 2Fast2Quik said:
* As long as your gpu is under 80 Degrees C and Cpu under 70 Degrees C
Well intel CPUs start throttling at 100°C, and 105°C is when heat starts making damage to CPU.
So 80°C is still fine for CPU. Not great or ideal, but it won't harm your CPU.
At least that's what I have been told.
WD My Cloud 4TB
https://linustechtips.com/topic/632101-temps/#findComment-8161254
60°C is my preferred temperature for 24/7 operation.
I have run CPUs at 80°C 24/7 and the thermal paste degraded faster and required annual replacement.
Modern CPUs are fine up to 100°C but I wouldn't recommend it for long periods, I would expect increased degradation of the thermal paste including the TIM under the heatspreader.
https://linustechtips.com/topic/632101-temps/#findComment-8161290
Exactly.
https://linustechtips.com/topic/632101-temps/#findComment-8161384
8 hours ago, Will Or occ said:
ok https://gyazo.com/d0cb19259149b7ef0e1f075f4a118109
the 4 numbers is the cores? right? also can u not look at the gpu?
At stock speeds 50 ish degrees is normal. Nothing fancy, so you should try overclocking now and get around 80-90 degrees
Blue screens eh? Did you try setting it to Wumbo?
https://linustechtips.com/topic/632101-temps/#findComment-8163123
