I bought a radio kit which is missing a capacitor. The capacitor which is missing has a value of 0.1 uF, can I use different values, like one that I have for 10uF? I am assuming that the capacitor is used for smoothing the signal. Will it work as long as it can supply .1 uF or more? Thanks.
PS It's a kipkay kit, and it was missing more parts, but I can just make the beginner one, instead of the hobbyist one.
Mathresolvermajig: Intel Core 2 Duo E8400 @ 3GHZ
Framepainting-inator: EVGA GT 730
Attachcorethingy: ¯\_(ツ)_/¯
Infoholdstick: 4x2GB sticks
Computerarmor: Lenovo Case
Rememberdoogle: 2 250 Gig Drives
AdditionalPylons: Generic 300 Watt
Letterpad: Lenovo
Buttonrodent: Lenovo
Aural Interface: Sony
Liquidrectangles: 1 1600x900 Vizio TV
https://linustechtips.com/topic/631333-radio-kitcapacitor-help/
1 minute ago, Electronics Wizardy said:
Use the same value. If you give the schmetic, i can see if something else would work
http://kipkaykits.com/fm-radio/
That's the link which has both schematics and both parts lists.
I ORDERED the hobbyist but basically received a beginner kit.
Letterpad: Lenovo
https://linustechtips.com/topic/631333-radio-kitcapacitor-help/#findComment-8152396
Radio Beginner Schematic
Letterpad: Lenovo
https://linustechtips.com/topic/631333-radio-kitcapacitor-help/#findComment-8152405
Those caps are being used as a high pass filter, and can't just be replaced with a different value, it would work, but it probably pull too much power form the chip and may burn it out. It also gets rid of dc offset.
https://linustechtips.com/topic/631333-radio-kitcapacitor-help/#findComment-8152414
Where did you learn all of this?!?
I want to learn, obviously :P
Letterpad: Lenovo
https://linustechtips.com/topic/631333-radio-kitcapacitor-help/#findComment-8152521
20 minutes ago, LabRat said:
sounds like a question for EEVblog.................. I would write/e-mail the company and make them send me one.
Does EEVblog run the kipkaykits?
Letterpad: Lenovo
https://linustechtips.com/topic/631333-radio-kitcapacitor-help/#findComment-8152525
I'm emailing the KipKayKit's support, they do ship replacement parts, they'll probably (hopefully) send me a new unit free!
Letterpad: Lenovo
https://linustechtips.com/topic/631333-radio-kitcapacitor-help/#findComment-8152534
You mean the 100n capacitor between VCC pin 5 and GND on the TEA5767? That's just there for power supply decoupling, the circuit should work fine without altough there could be the tiniest extra noise on the output. Replacing it with a bigger capacitor will render it pretty much useless as it will then no longer filter the high frequencies it's meant to, you might as well put no capacitor in in stead of a bigger one.
https://linustechtips.com/topic/631333-radio-kitcapacitor-help/#findComment-8152596
Just now, Unimportant said:
You mean the 100n capacitor between VCC pin 5 and GND on the TEA5767? That's just there for power supply decoupling, the circuit should work find without altough there could be the tiniest extra noise on the output. Replacing it with a bigger capacitor will render it pretty much useless as it will then no longer filter the high frequencies it's meant to, you might as well put no capacitor in in stead of a bigger one.
Hah, I just read about that too, it called it a bypass capacitor.
Is that the one you're talking about? the .1 uF?
I have a small orange capacitor that says 22 on it, can I use that?
Letterpad: Lenovo
https://linustechtips.com/topic/631333-radio-kitcapacitor-help/#findComment-8152607
No, that would be 22pF, about 50 times smaller then 100n. It would only filter frequencies so high they're not a problem anyway.
I'm also missing 2 different resistor values that're used for contrast and backlight control.
Could I use 2 potentiometers in that case? They're both from an old turtle beach headphone set.
I'll also just leave out the capacitor, it seems like it's not needed.
Letterpad: Lenovo
https://linustechtips.com/topic/631333-radio-kitcapacitor-help/#findComment-8152623
The 67 Ohm backlight resistor should not be replaced with a potentiometer, a pot will range from 0 to x ohms where x is the value of the pot. Turning the pot the wrong way (0) will blow the LED in the backlight. If you want adjustable backlight you can use a pot in series with a fixed 67 ohm resistor so you can never go below 67 ohm.
Constrast could be done with a potentiometer as long as the value is not off by orders of magnitude.
https://linustechtips.com/topic/631333-radio-kitcapacitor-help/#findComment-8152661
So if I replaced the 67ohm resistor with a higher value it'd work but be darker?
I have afew lying around which are near that value
Letterpad: Lenovo
https://linustechtips.com/topic/631333-radio-kitcapacitor-help/#findComment-8152676
Yes, it will get darker the higher the resistor value goes up until the point the LED's no longer reach their forward voltage, then it will cut out.
https://linustechtips.com/topic/631333-radio-kitcapacitor-help/#findComment-8152679
I have 2 100 Ohms 1% resistors, (Brown, black black black Brown) and another whose value is either 10k (Brown Black Black Red Brown) or 120 Ohms (Brown Red Black Black Brown)
Edited by jman116
Colors
Letterpad: Lenovo
https://linustechtips.com/topic/631333-radio-kitcapacitor-help/#findComment-8152683
You could try 100 ohm for the backlight. Might be a little dim but would probably work.
Would that work for the contrast as well or would it be really dark/light?
I can't tell what this other resistor's value is, there's no indication of which side to read from!
Letterpad: Lenovo
https://linustechtips.com/topic/631333-radio-kitcapacitor-help/#findComment-8152722
Normally, contrast on these LCD's is set with a potentiometer (10K for example) between VCC and GND and the center tap to the LCD contrast pin. Then you adjust the pot until you get a image. When connecting things straight to VCC trough a fixed resistor like done on the scematic it'll have to be the correct value.
https://linustechtips.com/topic/631333-radio-kitcapacitor-help/#findComment-8152748
So I can use the pot for the contrast, just not the back light?
Letterpad: Lenovo
https://linustechtips.com/topic/631333-radio-kitcapacitor-help/#findComment-8152753
For contrast yes, as long as the pot's value is reasonable, anything from 1K to 100K should work. Connected like this:
Use the 100 ohm for the backlight.
https://linustechtips.com/topic/631333-radio-kitcapacitor-help/#findComment-8152780
Thanks, I'll try that!
Letterpad: Lenovo
https://linustechtips.com/topic/631333-radio-kitcapacitor-help/#findComment-8152788
