Okay so I am modding this case and I have this gap in the front as you can see on the pics, what do you think would nice in there?
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/631305-modding-help-needed/
Will you ever be looking at it from the side? Or mostly front?
Because if only front, you could do some epic LED effects like that.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/631305-modding-help-needed/#findComment-8152083
mostly side
https://linustechtips.com/topic/631305-modding-help-needed/#findComment-8152087
I assume there are fans in the front, you could make a mesh or stepped portion or baffle with a small gap to still allow for airflow.
https://linustechtips.com/topic/631305-modding-help-needed/#findComment-8152092
I will put a 200mm fan in the front to suck out the hot air. I have tried the mesh and it is insanely hard to make.
https://linustechtips.com/topic/631305-modding-help-needed/#findComment-8152107
What are your plan for mounting the mesh you could create a bezel around the two edges and have it so the mesh bolts into place. For a baffle I was thinking you could create a recessed edge all one for each side the case portion and front plate with one of the offset to still allow airflow into the front but no direct line of sight to anything.
https://linustechtips.com/topic/631305-modding-help-needed/#findComment-8152130
well my plan was just to have a small edge on each side of the mesh I could glue to the case. The problem is just that the edge is round, not just sharp, so it is a lot harder to get the bend right and I don't have the best tools :D . I have been thinking of making a lot of small bars that would be as wide as the gap, but that also feels kinda meh.
https://linustechtips.com/topic/631305-modding-help-needed/#findComment-8152195
Yeah similar idea :D, well that would work using short sections as you wouldn't have to worry about bending the radius on the corners, only concern is without support or something for it to rest against it might require a bit of playing around to get the mesh to follow that curve perfectly. If you have the mesh recessed a bit so it's not flush to the two panels might be a little easier as you have some room for error. I assume you plan to bolt this mesh into place?
https://linustechtips.com/topic/631305-modding-help-needed/#findComment-8152224
well it is a alu case so it is easy to fuck up, so I am not sure about what I want to do with mounting them.
https://linustechtips.com/topic/631305-modding-help-needed/#findComment-8152243
Is the front solid aluminum I was thinking maybe using some very short screws to bolt those support bars into place but if it's very thin, a bit less conventional but you could use UHB tape (3M), which is just a very stick double sided tape that doesn't easily let go, no fear of accidentally drilling through or messing up the aluminum.
https://linustechtips.com/topic/631305-modding-help-needed/#findComment-8152275
tape it is :D
I have this kind of mesh on me right now, but I don't know how well it would look
https://linustechtips.com/topic/631305-modding-help-needed/#findComment-8152284
3 minutes ago, Dackzy said:
tape it is :D
I was thinking more on the lines of very fine honeycomb mesh as It might be a little hard to mount that into place, Maybe if you sandwich the mesh between the support bar on the back and a top plate but I'm not too sure how well that would clamp the mesh into place.
https://linustechtips.com/topic/631305-modding-help-needed/#findComment-8152311
Oh god that is hard to find in Denmark..
https://linustechtips.com/topic/631305-modding-help-needed/#findComment-8152348
