So I'm planning on getting two 360 radiators - one for the top and one for the bottom.
I plan on using the SP120 Performance from Corsair for both of them and I'm planning
on setting them up as intake as they would filtered that way.
For exhaust I plan on using the AF140 in the back.
So my question now would be:
Is this already enough? I have enough space for another 2 to 3 fans in the front but
I'm not really sure if they are needed. And in case I should get them: intake for more
air (even though I already am pretty positive) or exhaust to get closer to being slightly
positive/neutral?
The case is the Enthoo Primo if this information is relevant.
https://linustechtips.com/topic/631283-question-regarding-fan-setup/
having 6 intakes and only 1 exhaust tends not to do so well for general cooling, so I'd recommend either doing exhaust with one of the rads or front exhaust
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
