just use the onboard audio the headphones don't need to be powered by something like a fiio e10 or a sound card. Use the savings for better cans
https://linustechtips.com/topic/63120-audio-advice/#findComment-862594
I said that because you get better sound quality from the dac integrated with the E10, but I can't find a dac that has an output that goes to analog, so you kind of have to get an amp
https://linustechtips.com/topic/63120-audio-advice/#findComment-862598
I think that is a pretty awesome choice you may want to check out some of these amps, you get discount for being a LTT member http://www.mayflowerelectronics.com/headphone-amps.html. If you have the money. You can consult  MayflowerElectronics
But, beside that you can also get a Fiio E10
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/63120-audio-advice/#findComment-862599
Don't buy the sound card and you'll be good.
Case-NZXT H440 | Motherboard-Gigabyte Z77X-UD3H | RAM-Kingston HyperX Blue 2x8GB 1600MHz | CPU-Intel 3770K @ 4.3GHz at 1.215v | Heatsink-Coolermaster Hyper212 Evo | GPU-EVGA GTX660 SC | SSD-MX200 250GB | HDD-Seagate Barracuda 3TB | PSU-EVGA GS650
Mouse-Logitech G600 | Keyboard-Ducky Shine 3 MX Blue. white backlight | Headphones-Audiotechnica ATH-M50s. Beyerdynamic DT990
https://linustechtips.com/topic/63120-audio-advice/#findComment-862627
This soundcard includes a Headphone Amp, which is what you'll need to get the best performance. You could also go with a USB amp but at the price of that Sound Card, you may as well just stick with it.
For everyone saying just stick with onboard, you won't be getting the best performance from those headphones. They have an impedance of 50 ohms, which is enough that a Headphone amp would come in useful.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
https://linustechtips.com/topic/63120-audio-advice/#findComment-862634
Except that the amp used on soundcards have an output impedance of 10 which could cause funny business with headphones that have an impedance less the 80.
OP, get the headphones without the soundcard first, and see if your onboard is sufficiently loud. You can always add a soundcard or external DAC+amp later if desired.
https://linustechtips.com/topic/63120-audio-advice/#findComment-862735
