Case http://www.newegg.com/Product/Product.aspx?Item=N82E16811146080
wanting to install an AIO but worried I won't have clearance for it in the upper portion, was wanting an NZXT X61 but the site said it was incompatible with my case ( 280mm rad, 140mm x2 fans )
and it seems like most AIO's are 280mm.  It can fit 140mm fans in the top portion or a Rad, just worry it would fit a 280mm thick rad with 140mm fans
anyone can give some advice as to what might fit. From all the information I've gathered, RAD thickness might be a problem.
Only cooler I think that will work is an old h100 but they don't really make them at that size anymore with the V2
https://linustechtips.com/topic/630611-help-with-aio-case-compatibility/
Community Standards
"Beast Mode"
Dedicated Streaming Rig
1 hour ago, legacy99 said:
yeap, watched this and other videos, I'm concerned about thickness of the Rad as well since most rad's thickness very quite a bit
having weird issues where, if I select a 120mm rad it's really thick, or has 140mm fans and such,
just looking for a fairly thin rad 240mm, maybe 25-27mm thickness that uses 120mm fans.
