I have two choices, to upgrade my CPU and the motherboard or a graphics card. I wanted to upgrade to a 6700k and buy a motherboard for the 1151 socket, or buy a Gtx 1070 (I am going to buy both in the end)
So should i upgrade my CPU or my graphics card, my graphics card is getting pretty old right now, about 5 years, so is the CPU.
My current graphics card is the XFX Radeon HD 6850, and my CPU is the AMD Phenom(tm) X2 3.30 Ghz
I'm not sure if my graphics card is dying or is it just Windows 10, since i upgraded i've been having problems!
sorry if there is any spelling mistakes, I'm writing this too early!
https://linustechtips.com/topic/630117-what-should-i-upgrade-first/
Any reason for the 6700k? Could get something cheeper and save up a bit more and get it all. Please note you will need new RAM.
CPU: Intel i7-4790K @ stock for now --- RAM: Corsair Vengeance 16Gb --- MOBO: Asus Maximus VII Formula --- GPU: MSI Gaming GTX 980ti --- PSU: Corsair AX860i  ---  Storage: Samsung 850 250gb(OS), 3x Western Digital Blue 3tb (one for game and programs, two for media), 3tb WD Green(somewhat backup) and a Crucial M550 120gb SSD (caching games and programs drive)  --- Case: Fractal Define R5 --- Cooler: Corsair H100i with Noctua 2000rpm, Industrial Fans --- OS: Windows 10 --- Monitor: Asus PB298q + AOC l2260SWD --- Mouse: Logitech G502 Spectrum --- Keyboard: Corsair K70 (Cherry MX Red) Red LED's --- Audio: Audio Engine A2's (yes the originals), Sennheiser HD 58x Jubilee Audio-Technica ATH-AD900x, Audio-Technica ATH-M50x, Ant Lion Mod Mic V4 --- Laptop: Dell XPS 9750
I would go for i7 6700k first, then buy GPU.
That amd CPU already bottleneck your GPU most likely, so GTX 1070 wouldn't make any sense with that CPU xD
But you need to have decent PSU. Don't use some 430W that you got together with PC case.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
Agreed. It's not only CPU+GPU upgrade, you will need new RAM and a new PSU. Don't neglect the power supply ! I would also go for the combo CPU/mobo/RAM first, and then the GTX 1070. It makes more sense
CPU : i7 8700k @5GHz, GPU : ASUS GTX 1080 Ti STRIX, RAM : 2x8Go 3000MHz Corsair Vengeance, MB : ASUS Prime Z370-A, PSU : CM V850, Case :  NZXT S340, CPU Cooler : NZXT Kraken x62, Monitor : Acer Predator XB271HU 27" 1440p 165Hz, OS : Windows 10 Home 64 bits
Just now, DefaultTheVada said:
Well I have to buy a new GPU, my graphics card has died, now I have to use the HD 4500 graphics that come with the motherboard until my 1070 comes!
I hope your power supply is up to par.
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
woahhh man it's probably not worth upgrading that machine...you need both upgrades really bad...i would recommend you look at cheaper parts like i5-6500 and GTX 1060 or something...
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
