Triple Booting a 2014 MBPr, Need Help
Solved by patrickjp93,
7 hours ago, AlexTheRose said:I could RE it in IDA Pro, but ehhhhhhhhh that’s a lot of work for some little app. Not to mention I cannot read x86 assembly.
Owait, there is apparently source code in that SourceForge repo. Maybe you could get that compiling and modify it to suit your needs?
Sorry, should have updated this. I did get it working. I just didn't use rEFInd. I bootcamped Windows and then installed Fedora on its own partition. In order to get to MacOS, I have to hold down Option when booting, but that's no skin off my nose.
