This is really a bad idea unless you drive like a big SUV or MPV or something. Because your car doesn't actually produce much extra electricity. You could even burn up your car electronics.
The Internet is invented by cats. Why? Why else would it have so much cat videos?
https://linustechtips.com/topic/629574-charge-computer-from-car/#findComment-8131287
32 minutes ago, EcDarkSky said:
Hi guys i would like to charge my macbook air from the car and i don't find anything without a lot of bad comments.
Thanks for help
get an inverter
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/629574-charge-computer-from-car/#findComment-8131296
6 hours ago, Chr505 said:
Get one of these and use the mac port instead of the tomtom one
That would not provide the necessary power to power any computer, thats for GPS and Phones not for a full fledged computer.
https://linustechtips.com/topic/629574-charge-computer-from-car/#findComment-8133687
Used an Inverter with my 06 Ford Focus, Not one issue with the car.
https://linustechtips.com/topic/629574-charge-computer-from-car/#findComment-8133696
It might be enough for a Macbook Air but once the OP tries to use it with something more powerful then problems will arise.
https://linustechtips.com/topic/629574-charge-computer-from-car/#findComment-8135762
