Which solutions are there for faster Mbits speed
Solved by W-L,
22 minutes ago, Vinne said:W-L and DamnTarget. I meant specifically the internet speed-external network of each computer to the internet. We all have 100 mbps down-upload to internet each. But do you also need 100/1000/10000 fast cables and routers to have more than 100 mbps internet speed for each computer to internet. I will look into the speed of cables
If your talking about your internet connection speed to each computer you are paying for 100mbps down/up so you will only get that speed as it's your max. The speed between computers inside your network is different, if you wanted gigabit connections between all computer to communicate with each other that would require all the hardware to support gigabit connections.
