Hey guys! Im in need of some help. Im having a tough time picking between these 4 mice and I need your guys help. Im an FPS guy btw but I might play an MMO every once in a while. Which one should I pick and why? I also don't macro keys often.  P.S. Do not talk about any other mice I have looked and I only want these.
Steam ID: StormC2
"Better to be hated, then to be loved for what your not"
:ph34r:
https://linustechtips.com/topic/62824-mouse-help/
Can't go wrong with the logitech, solid mouse.
What type of grip do you have? claw? palm?
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/62824-mouse-help/#findComment-858378
Have you went to a store and tried them out yet? I currently use a R.A.T 7 Albino Edition, and it's pretty good. Im not going to vote since I haven't tried all of them yet.
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/62824-mouse-help/#findComment-858382
