Loosing speed?
Go to solution Solved by failblox,
What I think is happening here is that the cache (not the SSD part of the SSHD) on the SSHD is being filled up first with whatever it is you're trying to copy. This happens with my 4TB WD Black as well every time I try to copy file(s) that are decently large. The SSHD is slower than the cache, so after a while data gets backed up and it hits a bottleneck, thus slowing the transfer speeds slow down. The cache is substantially faster than the HDD itself, which is why you get such fast speeds at first, but since there isn't much, it slows down relatively quickly. Generally the cache is supposed to help make small file transfers quicker.
How come my pc always does this?
https://gyazo.com/7c9c9e772a85647c02aa771c3246750e
| CPU: Core i7-4790K  |  Motherboard:  MSI Gaming Z97 GAMING 5 LGA 1150  |  CPU Cooler:  NZXT Kraken X61 |
| GPU: Single 8GB EVGA GTX 1070 FTW |  RAMCorsair Vengeance 16GB (2 x 8 GB) DDR3 1600 MHz |  CaseCorsair 330R Titanium Edition
https://linustechtips.com/topic/628144-loosing-speed/
1 minute ago, Groundedbeef said:
what harddisk do you have?
1tb sshd.
https://linustechtips.com/topic/628144-loosing-speed/#findComment-8101405
1 minute ago, Vengeance_K1ng said:
1tb sshd.
not sure the model.
https://linustechtips.com/topic/628144-loosing-speed/#findComment-8101407
Every item or file that you want to transfer has to be registered and figured out what it is, the more items that is the slower it can be.
This is not a state of fact, it is my own though and through my own testing. But if you take 1 file, that doesn't have a lot of extra files inside of it or anything and transfer that file, you should get the full available speed.
https://linustechtips.com/topic/628144-loosing-speed/#findComment-8101411
I actually couldn't underclock my 5 year old GPU to make it as slow as a next-gen console.
#pcmasterraceproblems
~Slick
https://linustechtips.com/topic/628144-loosing-speed/#findComment-8101563
16 hours ago, Groundedbeef said:
Whats the rated speed of the drive and how is it connected?
Thanks Bud
https://linustechtips.com/topic/628144-loosing-speed/#findComment-8113339
