Hello.
Was thinking of building a pc and i would like some oppinions on the things i thought of putting in it.
so here is the parts list.
CPU                            Core i7 4770k
MOBO                         maximus VI Extreme
MEMORY                    G-Skill ripjaws 2x4 gb
GPU                            Gigabyte windforce 770 4gb x2
POWER                      Silverstone 1000W
CASE                          NZXT 810 Switch
CPU COOLER            Swiftech H220
So what do u think?
https://linustechtips.com/topic/62759-system-build-20132014/
Very expensive motherboard that could be swapped for a 150$ one without performance loss, do you really need an i7? You only put 8Gb of RAM, if you're doing some heavy editing/rendering, get 16Gb, if not, get the 4670k.
You should wait for the R9 serie from AMD, see how the price drops go, and maybe get a R9-290X or a 780.
It's better to get a single GPU at the moment, you'll be able to upgrade later.
PSU is overpowered, 800-850W would be fine
https://linustechtips.com/topic/62759-system-build-20132014/#findComment-857262
Pretty solid build. The only thing I would say is you could lower the size of your PSU and save a little.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/62759-system-build-20132014/#findComment-857266
This = more better
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU:  Intel Core i7-4770K 3.5GHz Quad-Core Processor  ($327.99 @ NCIX US)
CPU Cooler:  Swiftech H220 55.0 CFM Liquid CPU Cooler  ($129.99 @ NCIX US)
Motherboard:  Gigabyte GA-Z87X-UD3H ATX LGA1150 Motherboard  ($139.99 @ NCIX US)
Memory:  Mushkin Blackline 16GB (2 x 8GB) DDR3-1600 Memory  ($112.99 @ Newegg)
Storage:  Samsung 840 EVO 250GB 2.5" Solid State Disk  ($174.99 @ NCIX US)
Storage:  Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($84.99 @ NCIX US)
Case:  Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($122.98 @ Newegg)
Power Supply:  Silverstone Strider Plus 750W 80 PLUS Silver Certified ATX12V / EPS12V Power Supply  ($129.99 @ Amazon)
Other: Amd R-290X ($600.00)
Total: $1823.91
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-10-05 15:28 EDT-0400)
https://linustechtips.com/topic/62759-system-build-20132014/#findComment-857275
This = more betterPCPartPicker part list / Price breakdown by merchant / BenchmarksCPU:  Intel Core i7-4770K 3.5GHz Quad-Core Processor  ($327.99 @ NCIX US)CPU Cooler:  Swiftech H220 55.0 CFM Liquid CPU Cooler  ($129.99 @ NCIX US)Motherboard:  Gigabyte GA-Z87X-UD3H ATX LGA1150 Motherboard  ($139.99 @ NCIX US)Memory:  Mushkin Blackline 16GB (2 x 8GB) DDR3-1600 Memory  ($112.99 @ Newegg)Storage:  Samsung 840 EVO 250GB 2.5" Solid State Disk  ($174.99 @ NCIX US)Storage:  Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($84.99 @ NCIX US)Case:  Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($122.98 @ Newegg)Power Supply:  Silverstone Strider Plus 750W 80 PLUS Silver Certified ATX12V / EPS12V Power Supply  ($129.99 @ Amazon)Other: Amd R-290X ($600.00)Total: $1823.91(Prices include shipping, taxes, and discounts when available.)(Generated by PCPartPicker 2013-10-05 15:28 EDT-0400)
This but with this http://pcpartpicker.com/part/seasonic-power-supply-ss750km PSU
https://linustechtips.com/topic/62759-system-build-20132014/#findComment-857288
Or rm series psu. I prefer silverstone though :P But then again i'm sleeving the cables so i can say bye to their ugly cables.
The rm series runs dangerously hot so I wouldn't put in a case like the R4 which doesn't have high airflow.
https://linustechtips.com/topic/62759-system-build-20132014/#findComment-857309
I'm sure he picked the NZXT Switch 810 for a reason which is looks. The Switch 810 is in my opinion better looking/has better cooling than an R4.
My Gaming Rig;  Motherboard - ASUS Maximus VI Hero | CPU - Intel i5 4670k @4.5Ghz 1.25v | GPU - GIGABYTE GTX 980 @Stock | RAM -  16GB Corsair Vengeance @1866Mhz | CPU Cooler - Corsair H100i | Storage #1 - Samsung 840 Basic 250GB SSD | Storage #2 - Sandisk II 480GB SSD | Storage #3 - 2TB 7200rpm 64mb HDDPSU - Corsair HX750 | Case - Fractal Design R4 |
https://linustechtips.com/topic/62759-system-build-20132014/#findComment-857400
His board is fine people. Everyone always dogs on someone wanting a damn nice board. Normally the cheap people.
https://linustechtips.com/topic/62759-system-build-20132014/#findComment-857477
Yes i like the way NZXT 810 looks. And the maximus VI xtreme is around 360€ in Finland. And been using ROG boards in other pc:s too so i like them. But should i have more ram and the power is enough when its 850 for gigabyte gtx770 in sli.
Yes, 850 is enough for 770 in SLI however like others have said, a 780 will draw less power, create less stuttering and in most cases, give you more performance, I don't see why you need two 770's.. I'd say either 1 770 or a 780..
https://linustechtips.com/topic/62759-system-build-20132014/#findComment-857715
Yhis is a pure gaming pc.And im going to get the parts in december so. well see the prices and everything else at that point
An i5 will perform just as well as an i7 for gaming. 8GB ram is plenty for gaming. Getting more than you need will yield no benefit.
Plan later. Parts and prices change frequently and things will be very different by December.
A 770 sli will comfortably run on a 750w psu.
https://linustechtips.com/topic/62759-system-build-20132014/#findComment-862549
An i5 would perform just as well as the i7 for gaming.
Psu is overkill. A 750w would already be plenty for sli. 550w for single 770. Also, a 7970/280x has neck to neck performance with the 770 and is much cheaper.
Plan later. Parts and prices change frequently. I'd say plan 2-3 days at most before you actually purchase everything.
Does any1 know will two R280X ROG Matrix platinums fit in crossfire mode on the maximus VI extreme.cause those cards a triple slot cards.
It would fit but there's little point getting such expensive versions of a card that you can get much cheaper. It seems like you're throwing money at high end expensive parts hoping they would do better than the cheaper versions of the same thing. That's not how it works.
https://linustechtips.com/topic/62759-system-build-20132014/#findComment-902019
  • 2 weeks later...
Hello.
CPU                            Core i7 4770k
So what do u think?
The i5 4670k will be exactly the same performance as the i7 4770k in gaming.
With an Switchtech H220 Cooler, you are better off to get the Formula board. It will OC the same as the Extreme. Has better sound (wich for gaming is super important to me) and just looks kickass.
1000W can power 3 GPUs. With a costum WC loop. Go for a 750W PSU. this will power 2 GPU's perfectly fine.
NZXT Phantom windowed, Asus Z77 Sabertooth, Intel 2600K, Noctua NH-D14, EVGA 780 Classified, Crucial Ballistic Tactical, Crucial M4 128GB + Samsung 850 EVO, Corsair RM850, Creative X-Fi Fatal1ty Peripherals: Sennheiser HD598, FinalMouse Classic, SteelSeries Qck Heavy, Ducky Shine Zero (MX Brown), AOC G2460PF & Qnix QX2710
Build Log: Phantom - Antique Noctua
https://linustechtips.com/topic/62759-system-build-20132014/#findComment-944163
There is a 70 euro difference here between the cheapest and expencivest 280. But what psu for R280X ROG Matrix platinum in cross fire.
Grab the non-matric version off Asus and overclock it -> tada you now have the Matrix. 750W PSU. Either Corsair RM750 or Seasonic X750.
well we can say 2700-3400$ Nad ill be using my old HDD
Namibian dollars?
https://linustechtips.com/topic/62759-system-build-20132014/#findComment-944192
