New Drone Drifting Problem
Solved by Hackentosher,
If it's one of those palm sized ones, keep it in your house and terrorize your dog or smthn. As for the drifting, make sure that you plug it in and let the gyro do it's thing on a level surface. Perhaps when it was zeroing, it was tilted a bit. If this isn't the problem, remember it's still a cheap toy and it's not going to hold perfectly still like an Inspire 1. If the problem is really that big of a deal, you can just add some trim to the right on the roll axis.
These little things are great to learn on, what quad are you going to get after you learn the ropes?
