zip ties?
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/626391-wrong-sized-case-fans/#findComment-8082618
Yeah zip ties work great.
https://linustechtips.com/topic/626391-wrong-sized-case-fans/#findComment-8082624
40 minutes ago, Digital said:
But they look cheap and not so pleasing :o
Well yeah...because they are cheap...like a dollar...
If you want something more expensive that looks better then you may as well buy a new fan?
https://linustechtips.com/topic/626391-wrong-sized-case-fans/#findComment-8082927
I paid slightly too much for those fans, obviously because they are weird sized, nobody really uses that small fans. So not using them would be so big of a waste that it hurts :D
https://linustechtips.com/topic/626391-wrong-sized-case-fans/#findComment-8082948
Sell it used?
Use it for something else? like keyboard fan?
https://linustechtips.com/topic/626391-wrong-sized-case-fans/#findComment-8083218
