Hi guys! I am planning to drill some holes to mount a curtain, pictures, etc. I have this swiss military cordless drill that I will use to drill holes in the wall. I heard that you need this special tool so that you don't drill holes directly into a electric wire or something. What is that tool and where in Korea can I buy it? And also, what are some drilling tips? Thanks!
P. S. I didn't know where to put this so I put it in off topic.
https://linustechtips.com/topic/626381-help/
The tool you're looking for is a circuit tracer.
I have no idea where you can find one in Korea, seeing how I can't really use Google in Korean, but every DIY store should carry circuit tracers.
Also, drilling tips can mean many things...
But I would suggest that you make sure the wall you're drilling into is actually strong enough to hold what you plan on installing.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/626381-help/#findComment-8082509
25 minutes ago, ItsMinJunLol said:
How about a apartment wall? I'm planning to put stuff on my apartment wall and is what Luke's dad used in the whole room water cooling project also a circuit tracer? Thanks!
That depends on the type of walls that is used in your apartment.
It was mearly meant as a warning not to install heavy things on plaster wall. I speak from experience.
My best guess is that you'll be just fine mounting whatever on your walls.
I don't remember that from any of the Whole Room Watercooling videos. Could you link it with a timestamp?
https://linustechtips.com/topic/626381-help/#findComment-8082750
6 minutes ago, ItsMinJunLol said:
I'll post links below this and I can't find a circuit tracer. Can you find me one? I searched up korean e-malls and also amazon but It'll giv me circuit breakers...
I believe it's in this video -> https://www.youtube.com/watch?v=L6GVEx916ik
Hmm, maybe circuit tracer isn't the correct term. It might just be me sucking at English.
It might be called a wire detector.
You could look up a Bosch PMD 7. It's multi-detector that is capable of detecting wires.
https://linustechtips.com/topic/626381-help/#findComment-8082821
