Ok, so I just got my hyper 212 evo in the mail, which I know everyone is going to approve of. I need someone to confirm for me that you can fit a hyper 212 evo in an Inwin 303 case. Don't want, "should fit" I need to know. I'm not about to order a case that won't fit it. Also, any idea how bad it would be if I grinded  the heat pipes down a bit to make it fit? Or is that just a terrible idea
https://linustechtips.com/topic/626129-help-me-avoid-a-mistake/
Yes it will fit just fine. The cooler is 158.5 mm and the case is 572mm deep.
My Work in Progress PC http://linustechtips.com/main/topic/522048-xeon-build/ <-- That PC was built but never booted:(
My Work in Progress PC 2.0 https://linustechtips.com/main/topic/540583-xeon-build-20-code-name-xenox (Hopefully this one boots.)
https://linustechtips.com/topic/626129-help-me-avoid-a-mistake/#findComment-8079854
grinding down heat pipes would be silly. In the future, I recommend checking compatibility before purchasing. It should just fit
Main System Specs:
  • Intel Core i5 6500 3.2GHz CPU
  • Gigabyte GA-H170-D3H Motherboard
  • Kingston HyperX Fury 16GB 2400MHz, Gskill Ripjaws 8GB
  • Asus GTX 1060 Turbo
  • Kingston HyperX Savage 240GB SSD
  • Seagate 1TB NAS Grade HDD x2
  • Thermaltake NiC F3 Cooler
  • EVGA Supernova 750 G2 Power Supply
  • NZXT S340 Red/Black Case
  • Noctua NF-F12 Fan x2
Laptop Specs:
  • Intel Pentium N3700 CPU
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Microsoft Wired 600 KB
  • Dell 2003 Mouse
  • HP Compaq LA2206x Monitor
  • Logitech X530 5.1 Speakers
  • Roland RH-5 Headphones
https://linustechtips.com/topic/626129-help-me-avoid-a-mistake/#findComment-8079857
CM's website says 159mm, INwins site says 160mm.  That should leave you 1mm.  I definitely would not grind the heatpipes since they are'nt solid copper but a tube filled with a gas/liquid under pressure
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/626129-help-me-avoid-a-mistake/#findComment-8079862
Thank you so much, omf. I would have been the idiot that tried grinding them? Really appreciate the heads up bro, thanks a million
https://linustechtips.com/topic/626129-help-me-avoid-a-mistake/#findComment-8079882
no problem! Feel free to ask anything here, after searching on your own of course ;)
https://linustechtips.com/topic/626129-help-me-avoid-a-mistake/#findComment-8079890
The case is 572mm long and only 335mm deep. How deep a case is also doesn't determine whether a cooler will fit since the design could have used it for rear cable management.
https://linustechtips.com/topic/626129-help-me-avoid-a-mistake/#findComment-8083146
Yes you are right, my bad. Thank you for the correction.
Also to the OP I have found that the case can hold a cooler up to 160mm according to Inwin but people who have been able to get away with up to 172mm. So it will be a little close but you will be fine.
https://linustechtips.com/topic/626129-help-me-avoid-a-mistake/#findComment-8085681
What cooler were they using? Link?
https://linustechtips.com/topic/626129-help-me-avoid-a-mistake/#findComment-8085690
Dmitri over at Hardwarecanucks put a Dark Rock Pro 3 in and that cooler is 163mm. Here is the link to where I found found said information. https://pcpartpicker.com/forums/topic/168938-inwin-303-cpu-cooler-clearance Also on InWins spec page it has max CPU cooler height which I missed the first time.
https://linustechtips.com/topic/626129-help-me-avoid-a-mistake/#findComment-8085704
Oh, 172mm is the distance between the motherboard tray to the side panel and not from the socket. The case doesn't actually have 172mm of clearance.
https://linustechtips.com/topic/626129-help-me-avoid-a-mistake/#findComment-8085726
Oops I didn't read the whole post. I should really get some sleep. Still the OP should be able to fit his cooler as the official spec is 160mm.
https://linustechtips.com/topic/626129-help-me-avoid-a-mistake/#findComment-8085737
