  I listen to Rap/EDM, Game, want(don't need) 2 way noise isolation, and no mic. I would like to be able to listen to them with my phone. Durability is a must.
Which best fits my needs:
https://www.amazon.com/AKG-Pro-Audio-Reference-Headphone/dp/B00DCXZY1W/ref=sr_1_1?ie=UTF8&qid=1468437139&sr=8-1&keywords=akg+612+pro
or
https://www.amazon.com/gp/product/B00M3NZKA2/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A3QWSZ44N8P3XH
Motivation is where, and what you make of it.
“It is relatively unusual that a physical scientist is truly an atheist. Why is this true? Some point to the anthropic constraints, the remarkable fine tuning of the universe. For example, Freeman Dyson, a Princeton faculty member, has said, ‘Nature has been kinder to us that we had any right to expect.'”  Albert Einstein
https://linustechtips.com/topic/625921-need-help-chosing/
or
I really like my AKG K77s, but they are considerably cheaper than the ones you where looking at.
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
https://linustechtips.com/topic/625921-need-help-chosing/#findComment-8077592
What do you mean with "2 way noise isolation"?
The AKG K612s are an open pair of headphones, so they'll isolate diddly squad.While I would recommend them, they aren't really suitable for public use due to their sound leakage.
I never was a fan of the Urbanite series, but they do sound reasonable.
What exactly is your budget?
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/625921-need-help-chosing/#findComment-8077618
THe AKG K612s are an open pair of headphones, so they'll isolate diddly squad.While I would recommend them, they aren't really suitable for public use due to their sound leakage.
No noise can enter or leave the headphones. Roughly 120 dollars.
https://linustechtips.com/topic/625921-need-help-chosing/#findComment-8077633
In that case the AKGs are off the table.
My recommendation would be to look into the Sony MDR-7506 or the Sennheiser HD 280 Pros. Both have a slightly V.-shaped sound signature that should suite rap and EDM quite nicely.
https://linustechtips.com/topic/625921-need-help-chosing/#findComment-8077659
Those ear cups don't look exactly comfy...
https://linustechtips.com/topic/625921-need-help-chosing/#findComment-8077691
I have never had a problem with either, but results may vary.
As with everything, I would recommend trying them on before buying.
https://linustechtips.com/topic/625921-need-help-chosing/#findComment-8077702
Have you ever tried the urbanite xl, because that's the one I was wondering the most about?
https://linustechtips.com/topic/625921-need-help-chosing/#findComment-8077704
I have, and as said, I don't parricularly care for the way they sound.
Now, they don't sound bad (especially, for the price you linked), but they just aren't for me.
But they are comfortable.
https://linustechtips.com/topic/625921-need-help-chosing/#findComment-8077717
Now, they don't sound bad (especially, for the price you linked), but thry just aren't for me.
I actually found another one for $80.
https://linustechtips.com/topic/625921-need-help-chosing/#findComment-8077723
