Still deciding on a monitor setup for my 'soon-to-be' PC-Build
12 hours ago, mapegl said:About response times:
Yes 1ms is better than 8. Am I able to notice it? No. Would you be? Maybe.
So the response time thing is just, personal preference then? Understandable!
12 hours ago, mapegl said:Of course you can use the display ports on your gpu. The question is though: does it have enough? You can however use HDMI for 1080 p monitors. No difference there. That should give you enough ports.
The daisy chain might help you with cable length though, because one monitor will be kinda fear away from your PC.
I was thinking about having this:
This would my monitor setup:
[<<<>>>] <-Input=HDMI_FromGTX1080
[----][----][----] <- Input=DisplayPort_FromGTX1080
Key:
[<<<>>>] = Possible fourth monitor (Another Dell one or a Wide one) but I would buy and set it up in about 1-4 months after I've built the PC etc...
[----] = Dell Monitor(s)
If that fourth monitor were to be a Wide monitor, I know it would be strange when dragging like say Google Chrome onto that monitor from one of the Dell ones but that shouldn't be that much of an issue and if it is, well, LTT Forums will probably know what to do lol
Thankfully, the GIGABYTE G1 1080 has the right quantity of both DisplayPort and HDMI as shown:
So yeah, that should work out alright.
