Hello all!
A have a friend who lives across the other pond (In Australia) who has had the worst luck with laptops ever, (2-3 laptops dead in about a year. One brand new. The SATA connector was the problem I believe) (I don't have time to explain it but if you really want to know, just PM me or something) Anyway, his parents asked me to help them find one that wouldn't die in 6 months.
His requirements go something like this:
1. Price: 1000-1200 AU (About 750-900 USD)
2. Durability: Something that will be able to take some punishment (or at least one that doesn't flop around like a pancake) Also, a good record with reviews and owners is important.
3. Storage: Must be an SSD. 128GB will do fine (He's had 5 laptops over the years die from hard drive failure)
4. Cooling: Should be able to work fine in the heat. (40C/104F is the max temp)
Nice to haves
Gaming performance: Nothing special. Intel HD 520 will probably do.
RAM: He says 4GB is OK, but I'll say 6GB is the minimum.
Anyway, that's about it.
Thank you!
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/625225-finding-a-laptop-help/
12 hours ago, TheGhzGuy said:
Hello all!
Nice to haves
Thank you!
http://www.bestbuy.com/site/lenovo-thinkpad-yoga-2-in-1-14-touch-screen-laptop-intel-core-i5-8gb-memory-256gb-solid-state-drive-black/4456400.p?id=1219749486129&skuId=4456400
 very durable body, 8gbs ram, 256 ssd, dual core i5, nvidia GT 940m 2gb
Main Rig | Personal Build | Windows 10 | R7 2700x 3.7~4.3ghz | ASUS ROG Strix B450-I | 16gb DDR4 3200mhz | GTX 1080 FE | Coolermaster Elite 130 | Corsair H60 | WD Blue SN500 500GB NVMe SSD + 1tb WD Green HDD + 1tb WD Blue HDD
Laptop | HP m6-w102dx | Windows 10 | i7-5500u 2.4~3.0ghz | 8gb DDR3L | GT 930m 2gb| 120gb Sandisk SSD
Phone | Pixel 3 | Verizon | 64gb
https://linustechtips.com/topic/625225-finding-a-laptop-help/#findComment-8069592
4 minutes ago, Wedsea040 said:
ASUS K501UX
i7-6500U | GTX 950M 2GB | 8GB RAM | 256GB SSD | 1920 x 1080 | $749.99
Link
I certainly think this laptop could work !
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/625225-finding-a-laptop-help/#findComment-8069668
13 minutes ago, SlipperyPete said:
Great find! I'll see if I can try it at my local  Best Buy
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/625225-finding-a-laptop-help/#findComment-8069687
1 hour ago, TheGhzGuy said:
Hello all!
Nice to haves
Thank you!
Honestly, with that kind of pricing I'd grab something new from HP.  You're going to get a GREAT value out of it and on top of that, their new stuff really is 10x better than their older stuff (which still wasn't awful).
http://store.hp.com/us/en/pdp/Laptops/hp-envy-x360---15z-touch laptop-t5y05av-1
That is kinda my "ideal" $600-$800 notebook.  It will have tons of horsepower and great batter life.  Not to include a far amount of durability.  (customize it with a SSD instead of a HDD)
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/625225-finding-a-laptop-help/#findComment-8070266
I work at bestbuy and we carry this laptop. speaking from personal experience playing with it it is a nice, well built, enjoyable laptop to use. full aluminum, backlighting, and a good trackpad and keyboard!
https://linustechtips.com/topic/625225-finding-a-laptop-help/#findComment-8070675
Yep, I work part time at best buy right now, just trying to make some extra cash.  It really set a impression on me as far as build quality goes.  Although the one at best buy comes with a SSD automagically, but it also comes with a $800 price tag automagically.
https://linustechtips.com/topic/625225-finding-a-laptop-help/#findComment-8070701
Where is the option to switch it to an SD. I can't find it the configurator.
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/625225-finding-a-laptop-help/#findComment-8073645
just buy one and put it in it and get 250gb and not 128gb, that is just too little.
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/625225-finding-a-laptop-help/#findComment-8074564
Oh, I meant buy a aftermarket one and put it in after.  Trust me when I say you don't want a OEM install of Windows on the machine anyways.
https://linustechtips.com/topic/625225-finding-a-laptop-help/#findComment-8075327
23 hours ago, TheGhzGuy said:
Hello all!
Nice to haves
Thank you!
Point number 4, is definitely not going to happen, you won’t get a laptop with max temperature of 40 degrees Celsius. That’s not even possible on idle 10min after startup.
However, that’s just the core temperature, so don’t worry you aren’t going to feel that much heat. (except 5 hours long gaming session non-stop or similar application)
So forget about point number 4.
https://linustechtips.com/topic/625225-finding-a-laptop-help/#findComment-8076079
What I meant by that is Australia gets to be that hot on some days and I didn't want a laptop that has issues working in that environment.
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/625225-finding-a-laptop-help/#findComment-8076093
Ah OK then. I'm not sure that will work because that would probably push the computer over 1200 AU. Nor am I sure how to get it to Australia lol
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/625225-finding-a-laptop-help/#findComment-8076097
Ok, that makes sense.
I just wanted to inform you that 40 degree is impossible on a laptop.
But 60-80 degrees are possible.
https://linustechtips.com/topic/625225-finding-a-laptop-help/#findComment-8076114
I doubt it.  Just buy the Australian model.  The difference is usually just the wireless adapter.
https://linustechtips.com/topic/625225-finding-a-laptop-help/#findComment-8076117
But 60-80 degrees should be possible.
That I knew already. Sorry for the confusion.
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/625225-finding-a-laptop-help/#findComment-8076118
And in order to get a different copy of Windows they would obviously need to buy the Full version, correct?
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/625225-finding-a-laptop-help/#findComment-8076122
On 7/12/2016 at 11:33 AM, Wedsea040 said:
ASUS K501UX
Link
So, unfortunately, none of these laptops are available in Australia. So, back to square one.
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/625225-finding-a-laptop-help/#findComment-8078128
