Hi guys,
I've finished my new build, and although i think i did quite a good good managing the cables, there are still couple of things which bother me.
1. Is it possible to do something about the PSU cables?
2. Is it possible to do something about the cpu cooler cables?
https://linustechtips.com/topic/625099-cable-management/
2 minutes ago, timmywity said:
The cable on the cooler idk what you could do but for the PSU you could get some cardboard/card and cut and bend it so it covers the cables then paint it black and put it in the case
Good idea.
Do you have any pictures of this?
https://linustechtips.com/topic/625099-cable-management/#findComment-8068164
If your good with metal or wood you can make a PSU shroud and screw it into place. Acrylic also works well for this. As for the cooler cables, try run them to the top of the board and out the bottom.
Main System Specs:
  • Intel Core i5 6500 3.2GHz CPU
  • Gigabyte GA-H170-D3H Motherboard
  • Kingston HyperX Fury 16GB 2400MHz, Gskill Ripjaws 8GB
  • Asus GTX 1060 Turbo
  • Kingston HyperX Savage 240GB SSD
  • Seagate 1TB NAS Grade HDD x2
  • Thermaltake NiC F3 Cooler
  • EVGA Supernova 750 G2 Power Supply
  • NZXT S340 Red/Black Case
  • Noctua NF-F12 Fan x2
Laptop Specs:
  • Intel Pentium N3700 CPU
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Microsoft Wired 600 KB
  • Dell 2003 Mouse
  • HP Compaq LA2206x Monitor
  • Logitech X530 5.1 Speakers
  • Roland RH-5 Headphones
https://linustechtips.com/topic/625099-cable-management/#findComment-8068174
Maybe get a sheet of metal, bend it and attach it to the PSU (remember to paint it black)
I suck a typing, preparw for typos.
Desktop
CPU: Ryzen 7 3700x MOBO: MSI X570-A Pro RAM: 32 GB Corsair DDR4
GPUS: Gigabyte GTX 1660ti OC 6G  CASE: Corsair Carbide 100R STORAGE: Samsung Evo 960 500GB, Crucial P1 M.2 NVME 1TB   PSU: Corsair CX550M CPU COOLER: Corsair H100x
LAPTOP
Apple Macbook Pro 13 M1 Pro
https://linustechtips.com/topic/625099-cable-management/#findComment-8068220
Not sure about the cooler cable.
For the PSU you can google "psu cover" you'll find post explaining how some users did it.
some were able to get amazing results like this;
http://cdn.overclock.net/b/ba/ba3e9922_Covers22.jpeg
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/625099-cable-management/#findComment-8069007
