Hello,
There's the 550W version, and the 650W version. I was thinking of getting the 650W to make sure that if I upgrade at all I'm safe. Will this use up more electricity? Is it worse than the 550W (components changed slightly?)
https://www.amazon.co.uk/EVGA-SuperNova-Fully-Modular-Supply/dp/B0141B21JG?ie=UTF8&tag=pcp0f-21
My computer specs:
CPU: i7 3770k
GPU: EVGA GTX 1070 SC
RAM: 16GB
PSU: Corsair VS 450W
Thanks,
Oli
https://linustechtips.com/topic/625089-any-difference-between-these-psus/
2 minutes ago, TheKiwiColonel said:
Wil it use more power?
A PC will only consume as much power as it needs.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
In what sense? The "650W" or "550W" is the limit to these PSUs. However, how much they use while under load is entirely dependent on how much your PC itself pulls from the wall. The wattage of your rig itself determines how much more power it uses.
https://youtu.be/MPvj1cs77qA
alright, so for £5 more 100W more is a good idea.
Yes, I mean for that little of a price difference, you might as well. If only for peace of mind, you know?
I paid $95 for my RM750, when the RM650 was $90.
Sounds good to me.
EVGA has better quality components than Corsair's VS.
GPUs are getting more efficient so 550w should be enough.
If u want to SLI  then 650w should be enough.
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
2 minutes ago, HKZeroFive said:
Sounds good to me.
Cool, thanks guys I think I'll get it. Been recommended as a very good PSU, I assume you both agree?
Yeah, I'm going single but I might as well get 100W more for £5 just incase of future upgrades.
Yes, it's an excellent quality PSU.
The efficiency might be slightly different, but otherwise, no.
http://www.newegg.com/global/uk/Product/Product.aspx?item=N82E16817438054
I checked the model number, and they seem to be different? On newegg its slightly cheaper, so I'm a bit confused at the model number changing at the end from "Y3" to "Y1"?
edit: nevermind didn't realise newegg only sell from US, so the shipping is like £50 I'll just go with the amazon link.
£100 for my AX860 while RM650x is £90 :P
To OP, if prices are practically the same, get the bigger one.
Needs money for car parts :P
System specs: Core i7 9700k, Dark Rock Pro 4 , MSI Z390 PRO, 16GB CORSAIR VENGENCE DDR4 3000, ASUS RTX3080Ti, Corsair AX860, Seagate 1TB, Sandisk 240GB SSD, Samsung 1TB SSD, Corsair 400c
My Steam Profile (from SteamDB)
  • Worth: £654 (£221 with sales)
  • Games owned: 62
  • Games played: 52 (83%)
  • Hours on record: 2,980.7h
Probably a good option.
